BookmarkSubscribeRSS Feed
timothy_forsyth
Dec 16, 2015
JMP scripting
I have run 40 regressons which are saved as scripts to the data table.  I would like  to write a script that automatically extracts the R-squared value from each regression and puts them into a table
Drink deep, or taste not the Pierian spring
Jun 22, 2012
Re: JMP scripting
A couple of questions:
What platform did you use to run the regressions?
Did you run all of the regressions separatly?
Is the question you are asking, that you want to get the table of R-squared values generated from the saved script(s)?
timothy_forsyth
Dec 16, 2015
Re: JMP scripting
What platform did you use to run the regressions? I used JMP to run the regressions. Used the contextual X by Y platform
Did you run all of the regressions separatly? Yes I did
Is the question you are asking, that you want to get the table of R-squared values generated from the saved script(s)? This is exactly the question I am asking
Jun 22, 2012
Re: JMP scripting
Here is an example script on how to do what you requested.  It has a couple of assumptions.
1. The only scripts saved to the data table are the regression scripts
2. All of the regression scripts used the Fit Y by X platform and produced a "bivariate" output with "Fit Line" option selected.
dt = Current Data Table();
dtfinal = New Table( "R-Square" );
dtfinal << New Column( "X", character );
dtfinal << New Column( "Y", character );
dtfinal << New Column( "Column 1", character );
dtfinal << New Column( "R-Square" );
scriptNames = dt << get table script names;
For(i=1 , i <= N Items( scriptNames ), i++,
// Wrap an Outline Box around the script so a Handle can be
// attached to allow for referencing inside the analysis
ob = Outline Box( "test", dt << runscript( scriptNames[i] ) );
// Point to the Summary of Fit column and output it as a data table
tempDT = ob["Summary of Fit"][1] << make combined data table;
// Clean up the created data table
tempDT << select where( :Column 1 != "RSquare" );
tempDT << Delete Rows;
tempDT:Column 2 << set name("R-Square");
// Close the analysis
ob << delete;
// Concatenate the outputed table to the final table
dtfinal << concatenate( tempDT, Append to First Table( 1 ) );
// Close the temporary table
Close( tempDT, nosave );
