Oshova
Community Member
JMP interface - how to make it actually clickable
Hi evreyone
i could use some help
i want to make a report that when you click on the tab there is a window that opens beside it
the thing it is supposed to do is pull from the data base counter values - say the counter is 3000 for now
i want when i click it to do the next thing
if the counter<2500 - nothing
if the counter is 2500<counter<3500
i want it to say - need to replace X in ( formula - (3500-counter)/(nu of runs a day - let's say 500) ) days
can you help me wrute that in code ?
New Window( "Letters",
	V List Box(
		Align( center ),
		H List Box(
			Spacer Box( Size( 10, 15 ) ),
			Text Box( "TITLE" ),
			Spacer Box( Size( 10, 10 ) )
		Spacer Box( Size( 20, 10 ) ),
		Panel Box( "CHOOSE...",
			Radio Box( {"A", "B", "C", "D"} )
Re: JMP interface - how to make it actually clickable
I do not see a Tab Box object in your display tree. Perhaps you are referring to the radio buttons? If so, add this argument to the Radio Box() function call:
Radio Box( { "A", "B", "C", "D" },
	<< Set Function(
		Function( { me },
			choice = me << Get;
			Choose( choice,
				// option "A"
				// option "B"
				// option "C"
				// option "D"
