patrickbrown94
JMP holding on to file
Hi
I have been using JSL to open and close files of varying formats (.csv and .xls mostly)  and i have noticed that the close(dt, nosave) function doesn't release the edit lock on files i have closed. Even after I have closed JMP, the files often remain locked for editing/deletion.
Has anyone come across this problem. More importantly, does anyone know a solution?
Thanks
PB
troyhickey
Community Member
Re: JMP holding on to file
Hi Patrick, did you ever figure out how to release  files as you describe in your post?
Cheers, Troy
