Thierry_S
JMP > Graph Builder > Error Interval > Asymmetrical Error Bars?
Hi JMP Community,
Is it possible to assign asymmetrical error intervals in Graph Builder when using a custom interval?
Thanks.
Best,
TS
Thierry R. Sornasse
Byron_JMP
Re: JMP > Graph Builder > Error Interval > Asymmetrical Error Bars?
Yup!
In this table I have a column for high and low intervals
I drug both the high and columns to the interval role in the graph builder dialog to get this graph
From the graph builder script, you can see that the function can take two interval arguments.
Graph Builder(
	Size( 273, 296 ),
	Show Control Panel( 0 ),
	Variables( X( :group ), Y( :center ), Interval( :high ), Interval( :low ) ),
	Elements( Points( X, Y, Legend( 6 ) ) )
Byron_JMP
Yup!
Graph Builder(
	Size( 273, 296 ),
