BookmarkSubscribe
radhi
JMP diagram
Hello
Is there some action to do in order to improve the quality of the jmp path diagram before paste it on a word document?
what are the common index of fit (SAS and Amos) used to assess the quality if the confirmatory analysis?
Thank you
XanGregg
JMP diagram
You might have more luck if you post your questions separately. I don't know what a path diagram is, but in general you can sometimes get better output by using Paste Special in Word. JMP puts graphics on the clipboard in several formats and the pasting app chooses its default format (and Word and PowerPoint even have different defaults). Otherwise you can save the JMP graphic as a specific graphic file type like SVG or EPS which is more suitable for post-processing.
