BookmarkSubscribeRSS Feed
kevino_malley
Community Member
Apr 26, 2012
JMP closes when copy pasting output
Has anyone else experienced the following issue that my colleagues and I have?  If so, have you found a solution?
JMP closes when we copy & paste output from JMP into Microsoft Office products (Word, Excel, PowerPoint).  This does not always happen, but it does happen often.
peterj
Jun 23, 2011
Re: JMP closes when copy pasting output
I've had copy paste issues before pasting into JMP. When I contacted technical support they said it is a known issue and they have since been able to reproduce the error and were working on a fix (no timeline given). I'm not sure if your issue is the same as the one I have, but your best bet is to check the JMP crash log and report the issue.
I personally have never seen JMP crash when pasting from JMP into Office.
