BookmarkSubscribeRSS Feed
JMP application pass variables
DNAFoundry
Mar 17, 2017
I am trying to take a variable from a text box (variable name JOB_ID)  in applicaiton builder and use it as part of a concatonated string.
I have the code below as the press code in a button
SQL_Statement ="SELECT * FROM SAS_Plate_Reader  t1 Where Job_ID='"||Job_ID||"'";
New SQL Query(
	Connection(
		"ODBC:DSN=SQLite3 Datasource;Database=Z:\Projects\Project1014\Amos\J000g\SAS\SAS_Data.db;StepAPI=0;SyncPragma=NORMAL;NoTXN=0;Timeout=100000;ShortNames=0;LongNames=0;NoCreat=0;NoWCHAR=0;FKSupport=0;JournalMode=;OEMCP=0;LoadExt=;BigInt=0;JDConv=0;"
	QueryName( "SAS_Plate_Reader" ),
	CustomSQL( SQL_statement )
) << Run;
The error message i get is:
rgument should be character in access or evaluation of 'Concat' , Bad Argument( Job_ID ), "SELECT * FROM SAS_Plate_Reader  t1 Where Job_ID='" ||  /*###*/Job_ID ||  /*###*/"'" /*###*/
I think I dont understand the name space to pass the textbox to the script or how to concatenate a string properly, so any help appreciated!
thickey1
Jun 4, 2015
Try this
SQL_Statement ="SELECT * FROM SAS_Plate_Reader  t1 Where Job_ID='"||char(Job_ID)||"'";
I'm guessing your Job_ID os a numeric type and you are trying to concat this to a string. Need to cast to a string with teh char() fn.
DNAFoundry
Mar 17, 2017
I don't think it can be as it is a text edit box.
melaniedrake
May 30, 2014
It looks Job_ID is a variable that holds a texteditbox. What you need is the string that the texteditbox has in it. You can do that with the message Get Text.
In your code, try this (change in red):
SQL_Statement ="SELECT * FROM SAS_Plate_Reader  t1 Where Job_ID='"||(Job_ID<<Get Text)||"'"
