BookmarkSubscribeRSS Feed
JBNH
Community Member
JMP Tables Qry Builder with updated tables
I used JMP Table Query Builder to join 5 tables.and it worked great. I updated the 5 tables (replaced the old tables with the exact same name and new data). I used the Update from database database function in the table with the 5 table joins and the data didn't update. Will JMP Table query updated the joined table with the new data? Is JMP Table Qry or or Linked function the best way to virtually join tables for updated information?
