zainilmin
JMP Socket does not return data field from the web page get request? Can we get the json data from web request.
tCall = Socket();
rc = tCall << connect( "URL", "80" );
If( rc[2] == "ok",
    tCall << Send(Char To Blob(
        "GET /abc/123 HTTP/1.0~0d~0a~0d~0a",
        "ASCII~HEX"
    tMessage = tCall << recv( 486956 );
    print(tMessage);
    text = Blob To Char( tMessage[3], "utf-8" );
    //tCall << Close();
    text;
    rc[2]
Craige_Hales
Staff (Retired)
Re: JMP Socket does not return data field from the web page get request? Can we get the json data from web request.
try something like this:
tCall = Socket();
rc = tCall << connect( "jmp.com", "80" );
buffer = Char To Blob( "" );
While( rc[2] == "ok", // loop to receive all the data
  tCall << Send( Char To Blob( "GET / HTTP/1.0~0d~0a~0d~0a", "ASCII~HEX" ) );
  // 10000, below, is the max you'll get.  You will get what ever is actually available,
  // which usually won't be everything because of far-end delay and transmission time.
  rc = tCall << recv( 10000 );
  buffer = buffer || rc[3]; // concatenate all data
Show( rc ); // expecting {"recv", "CLOSED:  no data received." ...
text = Blob To Char( buffer, "utf-8" ); // convert
Show( text );
That code is not right.  This is better:
tCall = Socket();
If( rc[2] == "ok", // connected OK?
  rc = tCall << Send( Char To Blob( "GET / HTTP/1.0~0d~0a~0d~0a", "ASCII~HEX" ) );
  If( Left( rc[2], 7 ) == "CLOSED:", // ended as expected?
  Show( text ); // success!
  Show( "error", rc )
  Show( "could not connect!" )
Craige
