BookmarkSubscribeRSS Feed
ram_asra_gmail_
Mar 21, 2013
JMP Script
How to rename the script name  saved in a data table,
e.g I used
DataTable("Stacked")<<save script to data table;
now it always create a Script name "New Table".
i want to rename this as "PD-PU_Stacked".
how i can do that?
Thanks
-Ram
ron_horne
Jun 23, 2011
Solution
Re: JMP Script
hi Ram,
found this in the scripting guide, the last line is the answer.
ron
dt << New Script( "New Script", Distribution( Column( :Height, :Weight ), By( :sex ) ) );
Wait( 1 );
dt << Rename Table Script( "New Script", "Great Script" );
ron_horne
Jun 23, 2011
Solution
Re: JMP Script
hi Ram,
ron
Wait( 1 );
z2632941
Feb 4, 2015
Re: JMP Script
thank you
ram_asra_gmail_
Mar 21, 2013
Re: JMP Script
Thanks Ron.
