BookmarkSubscribeRSS Feed
JMP Script Question regarding saving Journal as PDF
Hoping someone can help out with the following question,
At the moment I'm saving jmp journals in a pdf format. Part of this process involves modifying the "page scale" setting under the "page setup" dialog box that pops up during the process.
Unforetuneatly, I don't see any instructions/examples where I can automate sending a script command to set the value of the page scale. Can this be done?
Appreciate your help. Thanks,
mattf
Jun 23, 2011
Hi:
Here is one way to modify the pdf's properties after creating it - via Perl and MS COM.
The Perl script can be kicked directly from JSL
Best regards,
-Matt
# References
# NESUG 2010 Multiple Methods in JMP® to Interact with R
# http://www.nesug.org/Proceedings/nesug10/po/po06.pdf
# NESUG 2009 Automating JMP via Scripting tools and MS Windows COM
# http://www.nesug.org/Proceedings/nesug09/ap/ap09.pdf
// open existing journal
jrn = Open("C:\Documents and Settings\mjflynn\My Documents\frb.jrn");
wait(1);
// save as pdf
jrn << Save pdf("C:\Documents and Settings\mjflynn\My Documents\frb.pdf" );
// modfiy saved pdf via Perl
SaveTextFile( "C:\temp\deleteme.pl","
     #http://search.cpan.org/~ssimms/PDF-API2-2.019/lib/PDF/API2.pm
     #!C:/Perl10/bin/perl.exe
     use strict;
     use warnings;
     use PDF::API2;
     # Create a blank PDF file
     $pdf = PDF::API2->new();
     # Open an existing PDF file
     $pdf = PDF::API2->open('frb.pdf');
     # Set the default print setting for page scaling to none.
     $pdf->preferences(-printscalingnone)
     # Add a blank page
     $page = $pdf->page();
     # Retrieve an existing page
     $page = $pdf->openpage($page_number);
     # Set the page size
     $page->mediabox('Letter');
     # Add a built-in font to the PDF
     $font = $pdf->corefont('Helvetica-Bold');
     # Add an external TTF font to the PDF
     #$font = $pdf->ttfont('/path/to/font.ttf');
     # Add some text to the page
     $text = $page->text();
     $text->font($font, 20);
     $text->translate(200, 700);
     $text->text('Hello World!');
     # Save the PDF
     $pdf->saveas('C:/temp/new.pdf');
SaveTextFile( "C:\temp\deleteme.bat",
                "C:\Perl10\bin\perl C:\temp\deleteme.pl"
Open( "C:\temp\deleteme.bat" );
tova
Feb 17, 2013
Re: JMP Script Question regarding saving Journal as PDF
How can I use Perl to change the orientation of my pdf file to landscape?
thanks,
Tova
