JMP Random Effect Model - but lists no parameter p-values?!
I have successfully run a linear regression using one independent variable with the random effects attribute. The model runs fine, but lists the parameters with only a dot under p-values (& DFDen). Does anyone know how to have the p-values listed as well? Thanks!
