gene
JMP Project saving modifications to derived tables
In a project I have loaded a data table.  Any time I make changes to that table, like adding a column, I can save the changes so they are persistant between sessions.  When I make say a summary table, the table is added to the project.  But now when I add a column and do some analysis based on the new column, the new column disappears wnen I close the project.  I guess the project just adds lines to a JSL script to rerun the summary table generation when I open the project.  But it does not sem to update the derived table with the modifications I make during a working session.  Do I have to save the summary table to disk in order to have the changes stick?  That would seem to defeat some of the advantages of using a project as a container.
