BookmarkSubscribeRSS Feed
jenkins_macedo
Jul 13, 2015
JMP Pro Access Violation Error?
What would be the most common reason for JMP Pro Access Violation Warning to be activated resulting in the software being closed while working assuming you are doing nothing wrong? This happens twice in less than an hour. None of my files were affected.
Jenkins Macedo
Eric_Hill
Oct 1, 2013
Solution
Re: JMP Pro Access Violation Error?
Hey, jenkins.macedo,
Access violations are caused by a bug in the software.  They are not your fault.  Your best bet is to report these incidents to SAS Technical Support so that they can check whether a software update might fix the problem, and, if not, report the problem to the development staff for resolution.
Thanks,
Eric
1 REPLY
Eric_Hill
Oct 1, 2013
Solution
Thanks,
Eric
