Share your ideas for the JMP Scripting Unsession at Discovery Summit by September 17th. We hope to see you there!
barrydecicco
JMP Pro 11 Can Not Save Reports
I'm running JMP Pro 11 on Windows.  I just installed it, upgrading from JMP 10 (I don't know if it was Pro).
I've run some partition models, and have found that I can't save the reports.  According to help, I just click on file > save,
but there are no menus at the top of the partition model window.   I've tried setting the preferences to get JMP to ask about
saving when I close the report, but that's not happening.
Does anybody know who to do this?
Barry DeCicco
bdecicco at med dot umich dot edu,
if the address doesn't show up.
Jeff_Perkinson
Re: JMP Pro 11 Can Not Save Reports
Hi Barry,
The menu in JMP report windows will drop down when you hover your mouse just below the title bar of the window.
Take a look at this blog post about the menus in JMP and it will explain how to get to the File -> Save.
If I've misunderstood the problem, please repost and we'll try again.
-Jeff
-Jeff
Jeff_Perkinson
Hi Barry,
-Jeff
-Jeff
barrydecicco
Thank you very much!
barrydecicco
I tried it this morning, and it worked.
Thanks again!
Article Labels
