BookmarkSubscribe
maltman
Community Trekker
JMP OLE: How to add a legend to a Bivariant
I can't figure out how to display a legend in my bivariant chart through OLE. There is very little documentation in JSL OLE (I'm I the only one doing this?). Can someone point me in the right direction? In it's current state, it will display the graph and color code by column. All I need to do is display the legend.
Here is my code (VBscript):
'Initialize JMP
Dim MyJMP, JMPDoc, DT, DT2, WidthTable, FrameBox
Set MyJMP = CreateObject("JMP.Application")
MyJMP.Visible = true
Set JMPDoc = MyJMP.OpenDocument("MyFile.csv")
'Convert document to datatable
Set DT = JMPDoc.GetDataTable
'Select the width data (High and Low)
DT.SelectRowsWhere "CHART_SUBSET",rowSelectEquals, rowSelectExtendCurrent,"TARGET=HIGH"
DT.SelectRowsWhere "CHART_SUBSET",rowSelectEquals, rowSelectExtendCurrent,"TARGET=LOW"
Set WidthTable = DT.subset
WidthTable.ColorByColumn("SPC_ENTITY")
WidthTable.MarkerByColumn("SPC_ENTITY")
'Create Bivariant Chart
Dim Biv
Set Biv = WidthTable.Document.CreateBivariate
Biv.LaunchAddY("SPC_CHART_VALUE")
Biv.LaunchAddX("SPC_TXN_DATE")
Biv.LaunchAddBy("SPC_CHART_SUBSET")
Biv.FitLine
Biv.Launch
FrameBox = Biv.GetGraphicItemByType("frame box", 1)
Biv.FrameBoxAddGraphicsScript 1, "Row Legend(:SPC_ENTITY)"
Biv.FrameBoxSetMarkerSize 1, 4
maltman
Community Trekker
Still looking for some help on this if anyone can provide some insight.
I tried something like this but it didn't work:
Biv.LaunchAddJSL "Row Legend(:SPC_ENTITY,color(1),Marker(1));"
Thanks
mattf
Community Trekker
Hi Maltman:
The allpurpose RunCommand() function will let one easily do anthing you like interactively directly in JMP,... and then if you capture the script, it is easy to submit that from the automation side, from VBA, or Perl, of Python, or R, etc...
Best,
-Matt
Public Sub test()
'Initialize JMP
MyJMP.Visible = True
Set JMPDoc = MyJMP.OpenDocument("C:/temp/Big Class.jmp")
Set DT = JMPDoc.GetDataTable()
DT.SelectRowsWhere "age", rowSelectEquals, rowSelectExtendCurrent, "12"
DT.SelectRowsWhere "age", rowSelectEquals, rowSelectExtendCurrent, "13"
Set WidthTable = DT.Subset()
WidthTable.ColorByColumn ("name")
WidthTable.MarkerByColumn ("sex")
'Create Bivariate Chart
Dim str As String
str = "Bivariate( " _
    & "Y( :weight ), " _
    & "X( :height ), " _
    & "Fit Line( {Line Color( {213, 72, 87} )} ), " _
    & " SendToReport( " _
    & "     Dispatch( " _
    & "       {}, " _
    & "     ""Bivar Plot"", " _
    & "      FrameBox, " _
    & "{Marker Size( 4 ), Row Legend( " _
    & "name, Color( 1 ), Color Theme( ""JMP Default"" ), " _
    & "Marker( 0 ), " _
    & "Marker Theme(""""), " _
    & "Continuous Scale( 0 ), " _
    & "Reverse Scale( 0 ), " _
    & "Excluded Rows(0)" _
    & "            )}" _
    & "    )" _
    & "  )" _
Debug.Print (str)
MyJMP.RunCommand (str)
End Sub
