BookmarkSubscribeRSS Feed
JMP Menu Editor and JSL
carole
Jun 23, 2011
I would like to use automatic menu customization in JMP, through JSL.
When opening a file with extension ".jmpcust" to customize the menu, a window named "JMP Menu Editor" appears.
The idea is to use this command in a script (at the beginning, each user with different name want to keep its own customization).
So I would like to close the window such as user do not see it, when starting running the script.
This syntax does not work :
schedule(2,
     win = Window("JMP Menu Editor");
     win << CloseWindow();
open("C:\Menucustom.jmpcust");
Thank you for your help !
