BookmarkSubscribe
gerardmcl
JMP - Fit Model row limit?
Within my script I load 338649 rows of data from an Oracle table and apply a Fit_Model (code below).
I then write the results back out to Oracle but I only get 7999 rows returned. I am missing data.
Is there a limit within JMP that is restricting the number of rows returned?
Mdl=Fit Model(
  Y( :MEAS ),
  Effects(
  :Name( "ColA" ),
  :Name( "ColB" ),
  :ColC,
  :Name( "ColD" ),
  :Name( "ColE" ),
  :ColF
  BY(:LOT,:PROD),
  Personality( Standard Least Squares ),
  Emphasis( Minimal Report ),
  Run Model(:MEAS << {Plot Actual by Predicted( 0 ),
  Plot Regression( 0 ), Plot Residual by Predicted( 0 ),
  Plot Effect Leverage( 0 )
rftmdl=Mdl<<report;
dt=rftmdl[1][Table Box(3)] << make combined datatable("Tbl_Combined");
current data table(dt);
dbc = Create Database Connection("DRIVER={Oracle in instantclient11_1};DBQ=DBQ;UID=UID;SPWD=PWD;");
for (i = 1, i <= nrows(dt), i++,
       sql_statement = .....
gerardmcl
Re: JMP - Fit Model row limit?
Turns out this is a setting on our database.
OPEN_CURSORS set to 8000 so it cuts off my INSERTS.
Now I will need to check if JMP can do the Insert a different way.
Does anyone know if JMP can do BULK INSERT?
