Botzal
JMP Exception! Error
Hi all,
When I try to run a script, I get this error. Why does this occur?
Thx
Re: JMP Exception! Error
There are many possible reasons this could have occurred. As specified in the error note, you can look into the .jer file for a possible reason.
Also, without seeing the script that resulted in this exception, there is no way to provide you with an answer.
You may want to contact JMP Support
support@jmp.com
