News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
jwubbel
JMP Connection with OLEDB Providers
While we have no trouble with regular ODBC database connections, can anyone advise on if JMP supports OLEDB connections using a PROVIDER within a script. I am trying to use the string connection information from a udl file I created that does a successful connection test to the database, however JMP seems to insist on having a DSN specified and that string does not work with Open Database or Create Database Connection callson. TIA.
mfisher
Re: JMP Connection with OLEDB Providers
The last time I checked ODBC was the only option.  However, if you have a SAS server, you can query data via OLEDB, Oracle, Sybase, etc. if you use JMP to connect to the SAS server and submit pass-through SQL code using those database connections.
stan_koprowski
Hi John,
I just created OLEDB Database Tools Addin to help with this task.
Try it out and let me know what you think.
Best,
Stan
