JMP Application Module as Modal Dialog
insider
Jul 26, 2012
Maybe I couldn't find the simple way to do it but is there the possibility to set a module as modal dialog in JMP Application (JMP 10) ?
I would like to instantiate a module from another and make it modal at opening.
Thanks for your support.
teresa
Jun 23, 2011
Hello Insider,
I do not know if I understand your question very well, but in
C:\Program Files\SAS\JMP\10\Samples\Scripts
there is the file
JMPStarter.jsl
that:
"// JMP Starter
// This is an example of how to build a customized JMP Starter, with shortcuts to any
// groups of analyses that you find useful."
Are you familiar with JMP Scripting Language (JSL)?
Is this the one you are looking for?
Best,
Teresa
insider
Jul 26, 2012
Hello Teresa,
Thanks for your reply, I had a look into the code of JMPStarter.jsl. I guessed the way to set the window modal:
New Window( "JMP Starter",
  Dialog, // <--
But my problem is I would like to deal with JMP Module in the Application Builder. I have a module named MainWindow with these settings:
And in this module I have a button to open a second module called DialogWindow (Module type: Dialog, Auto Launch unchecked).
Here is the code of MainWindow module:
// This special function will receive parameters passed to CreateInstance()
OnModuleLoad({},
thisModuleInstance << Create Objects;
// After this point your module instance objects have been created
// and can be referred to by name (for example, "Button1").
Button1Press=Function({this},
  // This function is called when the button is pressed
  DialogWindow << Create Instance( );
Does it exist a way to set the "DialogWindow" instance modal ?
Thanks for your help.
