Hello JMP Community,
OS details: W10 Enterprise, 64-bit, 32 GB RAM, JMP 14.0.0 and JMP Pro 14.1.0.
Hoping that I can find a solution to an issue that's puzzling me. I have a colleague who is trying to generate some graphs in Graph Builder, but the JMP-generated script that is saved to the data table keeps crashing, and does it at random times. Sometimes the code is stable for 1-2 minutes, other times for 30+ minutes. Colleague is running JMP 14.0.0.
My colleague sent me the data table, which I opened in JMP Pro, and it seems to be quite stable there, didn't have any issues even though I had it open for 30+ minutes.
Then, opened same data table in regular JMP (after closing in Pro) and tried running the script, but it crashed after a couple minutes.
Doesn't seem to be a memory size issue, but could be a JMP version issue?
I've read from other posts this could happen when writing your own script to perform tasks, but this is all script generated by JMP. This would suggest to me that there is an issue with JMP, and that under some strange circumstances, it doesn't script things quite right. Is this possible? Is it a JMP bug? If so, hopefully it's known and has been corrected for version 15.
Below is the script with the names changed to protect the innocent.
Thanks!,
DS
Graph Builder(
Size( 1006, 863 ),
Variables(
X( :Name( "Column X1" ) ),
Y( :Name( "Column Y1" ) ),
Y( :Name( "Column Y2" ) ),
Y( :Name( "Column Y3" ) ),
Y( :Name( "Column Y4" ) ),
Overlay( :Man ),
Color( :Man )
Elements(
Position( 1, 1 ),
Points( X, Y, Legend( 8 ) ),
Ellipse( X, Y, Legend( 9 ) )
Elements(
Position( 1, 2 ),
Points( X, Y, Legend( 7 ) ),
Ellipse( X, Y, Legend( 10 ) )
Elements(
Position( 1, 3 ),
Points( X, Y, Legend( 6 ) ),
Ellipse( X, Y, Legend( 11 ) )
Elements(
Position( 1, 4 ),
Points( X, Y, Legend( 4 ) ),
Ellipse( X, Y, Legend( 12 ) )
Local Data Filter(
Add Filter(
columns( :Year, :Country ),
Where( :Year == 2010 ),
Where( :Country == {"Country 1", "Country 2", "Country 3"} ),
Display( :Country, Size( 181, 68 ), List Display )
Dispatch(
"400",
ScaleBox,
{Legend Model(
7,
Base( 6, 0, 0, Item ID( "Anon 1", 1 ) ),
Base( 7, 0, 0, Item ID( "Anon 2", 1 ) ),
Base( 8, 0, 0, Item ID( "Anon 3", 1 ) ),
Base( 9, 0, 0, Item ID( "Anon 4", 1 ) ),
Base( 10, 0, 0, Item ID( "Anon 5", 1 ) )
), Legend Model(
10,
Base( 6, 0, 0, Item ID( "Anon 1 (90%)", 1 ) ),
Base( 7, 0, 0, Item ID( "Anon 2 (90%)", 1 ) ),
Base( 8, 0, 0, Item ID( "Anon 3 (90%)", 1 ) ),
Base( 9, 0, 0, Item ID( "Anon 4 (90%)", 1 ) ),
Base( 10, 0, 0, Item ID( "Anon 5 (90%)", 1 ) )
), Legend Model(
6,
), Legend Model(
11,
), Legend Model(
4,
), Legend Model(
12,
Dispatch( {}, "Graph Builder", FrameBox, {Marker Size( 6 )} ),
Dispatch( {}, "Graph Builder", FrameBox( 2 ), {Marker Size( 6 )} ),
Dispatch( {}, "Graph Builder", FrameBox( 3 ), {Marker Size( 6 )} ),
Dispatch( {}, "Graph Builder", FrameBox( 4 ), {Marker Size( 6 )} ),
Dispatch(
"400",
LegendBox,
{font( "Segoe UI", 14, "Plain" ),
Legend Position(
{8, [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10], 9, [-1, -1, -1, -1, -1, -1,
-1, -1, -1, -1, -1], 7, [-3, -3, -3, -3, -3, -3, -3, -1, -1, -1, -1],
10, [-3, -3, -3, -3, -3, -3, -3, -1, -1, -1, -1], 6, [-3, -3, -3,
-3, -3, -3, -3, -1, -1, -1, -1], 11, [-3, -3, -3, -3, -3, -3, -3,
-1, -1, -1, -1], 4, [-3, -3, -3, -3, -3, -3, -3, -1, -1, -1, -1], 12,
[-3, -3, -3, -3, -3, -3, -3, -1, -1, -1, -1]}
), Position(
{0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, -1, -1, -1, -1, -1, -1, -1, -1,
-1, -1, -1, -3, -3, -3, -3, -3, -3, -3, -1, -1, -1, -1, -3, -3, -3,
-3, -3, -3, -3, -1, -1, -1, -1, -3, -3, -3, -3, -3, -3, -3, -1, -1,
-1, -1, -3, -3, -3, -3, -3, -3, -3, -1, -1, -1, -1, -3, -3, -3, -3,
-3, -3, -3, -1, -1, -1, -1, -3, -3, -3, -3, -3, -3, -3, -1, -1, -1,
-1}
