BookmarkSubscribeRSS Feed
mikehd
Jun 23, 2011
JMP 8.0.2 - can't save profiler as flash object
Hi all,
I've been searching for help on this one and thought I'd try a post here.
I'm running JMP 8.0.2 and have read a few tutorials on how to embed a profiler into powerpoint presentation as a flash object. The problem is that I don't have this "save as" option when I click the red triangle hotspot on my profiler. Is there a hidden setting that I need to change, or perhaps my company's JMP admin has disabled this?
thanks for your help,
Mike
9 REPLIES 9
Jeff_Perkinson
Community Manager
Jun 23, 2011
Re: JMP 8.0.2 - can't save profiler as flash object
The profilers built into the modeling platforms don't have the option to save as flash.
Instead, save the prediction formula(s) for your response variable(s) and then use the Profiler from the Graph menu on the saved column(s).
You'll find the Save As Flash option in the red triangle there.
Jeff
-Jeff
mikehd
Jun 23, 2011
Thanks, that did the trick.
Did I misunderstand the help file and SAS' own instructions? It sure made it seem that the modeling platform had this capability baked into it.
Update: I think I got off on the wrong foot by not understanding JMP's terminology. I was in the modeling platform trying to do this not in the profiler platform.
thanks again...
Message was edited by: mikehd
ron_horne
Jun 23, 2011
when exporting the prediction formula and using it in the profiler platform is there a way of preserving the confidence intervals?
luigi
Jul 1, 2011
Yes,
After you first Save Columns>Prediction Formula also choose Save Columns>StdErr Pred formula. Then when you invoke the Graph>Profiler platform be sure to add both the Prediction Formula as well as the StdErr Prediction Formula to the dialog box.
ron_horne
Jun 23, 2011
for some reason this is not working for me, i have tried in many ways without success, could you please send me an example?
luigi
Jul 1, 2011
First Fit your model and then chose Save Columns>Prediction Formula
Then Save Columns>Std Err Pred Formula
Then in the Graph>Profiler platform populate the dialog box with both the Pred Formula and PredSE
Result Profiler with confidence intervals
ron_horne
Jun 23, 2011
thanks!
now i managed to do it but if i save as Flash i loose the confidence intervals. is there a way of showing them in the final Flash version?
Jeff_Perkinson
Community Manager
Jun 23, 2011
The Flash Profiler doesn't support the confidence intervals. Sorry.
-Jeff
-Jeff
ron_horne
Jun 23, 2011
thanks Jeff.
