    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
Neo
Neo
JMP 16 to JMP 18- get Legend Server/Item question
I recently moved from JMP 16 to JMP 18 and the following line in my script is causing an error while plotting using the graph builder
server = gb_obj<< Get Legend Server; For Each({item}, server << Get Legend Items, 	item << Set Properties({Marker("Minus")}));
where gb_obj is the graph builder object and error is
Send Expects Scriptable Object at row 6 in access or evaluation of 'List' , {/*###*/LegendModelItem( Label( "meas_para_name" ), Type( "Marker" ) )}
where "meas_para_name" is the name of a measured parameter in the data table plotted.
What to change to get this to work on JMP18?
(let me know if above info is not enough)
When it's too good to be true, it's neither
hogi
Level XIII
Re: JMP 16 to JMP 18- get Legend Server/Item question
workaround: use get legend item() for each item.
issue with get legend items
[fixed in JMP19]
Neo
Neo
@hogi Thanks. Below (with for each) does not work in JMP 18. What am I missing?
server = gb_expr_obj<< Get Legend Server; For Each({item}, server << Get Legend Item (), 	item << Set Properties({Marker("Minus")}));
hogi
Level XIII
Use Get legend Items in a first step. And use "i" as index for the second step:
server = gb << Get Legend Server;
Nitems = Nitems(( server << Get Legend Items)[1]);
for(i=1, i<= Nitems, i++,
Eval(Eval Expr(item = server  << Get Legend Item(1, Expr(i))));
	item << Set Label( "Item " || Char( i ) )
If you have multiple layers, you might need to change the first index as well.
Neo
Neo
@hogi When is JMP 19 getting released?
hogi
Level XIII
2025-09
