vishwasanj
Dec 27, 2016
JMP 13 script on JMP 12
My other remote computer had JMP 12 installed and I was curious to see the output of my jmp addin.
The addin/script works fine on JMP 13. But on JMP 12, it's evaluating everything till the final table and stops.
The error I get is " evaluation of the preference not chosen for 'open file after export'". Any idea what this is? Where should I change?
Thank you,
1 REPLY
Craige_Hales
Mar 21, 2013
Re: JMP 13 script on JMP 12
I don't find that exact message, but it sounds like your script might include a JMP 13 preference that does not exist in JMP 12.  "Open the file after saving" appears in the save-as dialog for some file extensions.
Craige
