BookmarkSubscribeRSS Feed
tova
Community Trekker
Feb 17, 2013
JMP 12 saving to PDF x-axis shifting
Hi.  I am trying to run the same script I used to run on JMP 11 on JMP 12.  It worked flawlessly on JMP 11.  I generate a lot of graphs, save them to a journal and then save the journal to pdf.  When JMP 12 saves the journal to PDF, it shifts the x-axis in the pdf.  The week number starts under the third bar instead of under the 1st bar.  Any idea why this is happening or what I can do to fix this?
Jun 22, 2012
Re: JMP 12 saving to PDF x-axis shifting
It sounds like a bug to me.  I would report it to
     support@jmp.com
so they can verify it, and if it isn't already known, get it in line to be fixed in one of the JMP 13 releases.
tova
Community Trekker
Feb 17, 2013
thanks
