BookmarkSubscribeRSS Feed
kreyandor1230
Aug 28, 2015
JMP 12 database
Hi, I am very new to JMP. I know that JMP can access database but does JMP come with a database of some sort?
gail_massari
Community Manager
Feb 27, 2013
Solution
Re: JMP 12 database
JMP does not come with a proprietary database so that we don't limit you to using only one database. It is intentional that you can access all common databases that you might have, easily put them in JMP tables that you can manipulate, and then do the analysis in JMP. It's power is in analysis, visualization, linking information with graphs to the data after it is in a JMP tables, easily saving analyses to be re-run, and more.
gail_massari
Community Manager
Feb 27, 2013
Solution
Re: JMP 12 database
kreyandor1230
Aug 28, 2015
Re: JMP 12 database
Thanks for the info, it was very helpful.
Eric_Hill
Oct 1, 2013
Re: JMP 12 database
I will just add that will all of the free databases out there (MySQL, PostreSQL, SQLite, SQL Server Express), if you need a database, there are plenty available at no cost to you.
Eric
kreyandor1230
Aug 28, 2015
Re: JMP 12 database
THanks for the information, I will check them out
