BookmarkSubscribeRSS Feed
scott_87
Feb 22, 2013
JMP 11 EVAL() or partition problems
Hi Guys I have a problem when I run this code on JMP 11, its crashes out but works on JMP 10.
Basically i run the for loop below that edits columns and it works fine but once i run a partition analysis after, it crashes. Both subsets of code work fine on their own, if i just run the partition analysis it works fine, if i just run the for loop it works fine, so i believe its an interaction between the two on JMP 11. This code works perfect on JMP 10, any ideas?
for(i=1,i<=nitems(colNames),i++,
  if(!contains({"EQUI","SLOT","DOSE"},substr(colNames,1,4)),continue());
  summarize(b=by(column(dt1,colNames)),n=count());
  if(nitems(b)<2 | sum(n<6)<1,continue());
  ex={};insert into(ex,b[loc(n<6)]);
  eval(parse("r=dt1<<get rows where(contains("||char(ex)||",name(\!""||colNames||"\!")))"));
  if(nrow(r)==0,continue());
  column(dt1,colNames)=empty();
pat = Partition(
    Y( eval(yCol) ),
    X( eval(xCols) ),
pmroz
Jun 23, 2011
Re: JMP 11 EVAL() or partition problems
Try putting wait(0); between the two code pieces.  That will allow JMP to catch up to itself.
scott_87
Feb 22, 2013
I tried wait(0); but no joy, it seems like a JMP 11 bug, here's the error message:
