natalie_
Level V
JLS- Divide Column by a Value
Hi again,
I am writing some script which opens several csv files and joins them; it is working well!
In one column, I'd like to divide the values of another column by a value.  I just can't figure it out.  I can do it on the formula editor though, but I don't believe I can use that syntax while scripting.
    dt << New Column(".");  //just to create a blank column
    dt << New Column("Id(A/mm)");
    col = Column("Id(A/mm)");
    col << Set Formula(Column("Id(A)")/Wg);
    col << EvalFormula;
[code/]
David_Burnham
Re: JLS- Divide Column by a Value
something like this maybe:
someNumbers = 1::10;
New Table("demo",
    Add Rows(10),
       New Column("Sequence", numeric, continuous, <<Set Values(someNumbers) )
col = New Column(".", numeric, continuous);
valueToDivideBy = 2;
col << Set Formula(:Sequence/valueToDivideBy);
// or ...
col = New Column("..", numeric, continuous);
col << Set Formula( AsColumn("Sequence")/2);
-Dave
David_Burnham
New Table("demo",
    Add Rows(10),
// or ...
-Dave
There is an issue with the first solution provided by David.  While the code will work, the formula created is:
Since "valueToDivideBy" is a scalar memory variable, that will go away once the JMP session is closed, or could change value during the course of the day's processing, the calculated value of "col" could become invalid or incorrect.  The second version of the formula would be preferred.  However, if you want to use the structure of the first solution, you could do a couple of things:
1. Change the Se Formula to:
     col << Set Formula(Eval(Parse(":Sequence/"||char(valueToDivideBy)));
2. Convert the formula to static values once the formula has been applied.  To do this, add the following line after the the col << Set Formula line
     col << delete property("formula");
David_Burnham
yes, well spotted.  thanks
-Dave
natalie_
Level V
I chose to use David's second method.  I think I understand why his first method has an issue, but I was unable to make your suggested changes.  As I run the script, I can make all the new column, but the formulas are not working.
  col= new column("."); //add blank column
  col=New Column("Id(A/mm)",numeric,continuous);
  col<<Set Formula(Eval,Parse(":Id(A)/"||Char(Wg)));
  col<<delete property(":Id(A)/"||Char(Wg));
