BookmarkSubscribeRSS Feed
ajgarnello
Iteration Questions: Data Filtering, and File Saving-Naming
I am wondering how to setup a code that iteratively runs an analysis according to a specific data filter, and then repeat that analysis for a new data filter. The data filter is set to exclude rows based on the presence of a 1 or 0 in a column, and the columns are in sequential order. Here is an example script:
dt = Open("Hyperspectral_DataCleanedOrdered.jmp");
dt << Data Filter(
  Mode(Include(1)),
  Inverse,
  Add Filter(
  Columns(Rand001),
  Where(:Rand001 >= 0.875 & :Rand001 <= 1)
doDiscriminant =
Expr(
  da = dt << Discriminant(
  X( :Site Type ),
  Y(
  :Name( "366" ),
  :Name( "367" ),
  :Name( "368" ),
  :Name( "369" ),
  :Name( "370" ),
  :Name( "371" ),
  :Name( "372" ),
  :Name( "373" ),
  :Name( "374" ),
  :Name( "375" ),
  :Name( "376" ),
  :Name( "377" ),
  :Name( "378" ),
  :Name( "379" ),
  :Name( "380" ),
  :Name( "381" ),
  :Name( "382" ),
for(i=1, i<=10, i++,
  doDiscriminant;
  da << StepwiseVariableSelection;
  for(k=1, k<=i, k++, da << stepForward);
  da << applyThisModel;
  daRep = da << Report;
  daRep["Score Summaries"]<<select;
  daRep["Score Summaries"] << Journal("test1");
  Current Journal() << Append(text Box("Test1"));
  daRep << closeWindow;
Current Journal() << Save Journal ("Rand001") [Ideally, this name updates with each iteration]
The discriminant analysis is on loop for a certain amount of stepwise variable selection iterations (10): What I want is for each 1-10 iteration of the discriminant analysis to occur for each iteration of a data filter. The data filter is set to read a column (Rand001, Rand002,...Rand100), and than exclude specific rows based on the content of the column.
Also, I wasn't able to find a simple way to save journals/text files iteratively with a name that updates per-iteration, so that is another piece of useful advice here.
Thank you!
vince_faller
Re: Iteration Questions: Data Filtering, and File Saving-Naming
I don't think I answered all of your questions but this might put you on the right track.
dt = open("$SAMPLE_DATA\big class.jmp");
dt<<New Column("Rand001", Formula(Random Integer(0,1)));
dt<<New Column("Rand002", Formula(Random Integer(0,1)));
dt<<New Column("Rand003", Formula(Random Integer(0,1)));
for(i = 1, i<=3, i++,
      col = Column("Rand00"||char(i));
            X( :sex ),
            Y( :height ),
            Where(col[row()] == 1),
            Show Classification Counts( 1 ),
            Biplot Ray Position( [0, 15.5914608488282, 1.5] )
      da << Title("Rand00"||char(i));
      da << Redraw;
      da << Journal;
      da << Close Window();
I would use either the where statement or the local data filter.
hope it's at least somewhat useful.
Vince Faller - Predictum
ajgarnello
Thank you for that help, it has given me some insight on my next steps. Though, what I was looking for was to iteratively apply a data filter, not iteratively run the DA. Example, here is a sample code:
dt = Current Data Table();
col= Column("Rand00"||char(i));
doDataFilter =
  dt << Data Filter(
  Mode(Include(1)),
  Inverse,
  Add Filter(
  Columns("Rand00"||char(i)),
  Where(:col == {1})
//Where(:"Rand00"||char(i) > 0.875 & :"Rand00"||char(i) =1)
for(i=1, i<=3, i++, doDataFilter;
col= Column("Rand00"||char(i)););
This code reads the error:
The WHERE clause has not been correctly specified. in access or evaluation of 'Equal' , :col ==  /*###*/{1} /*###*/
How can I write the WHERE clause to include the 'i' character, so that the filter moves along the designated rows with each iteration?
vince_faller
I guess then what's the purpose of excluding?  If you're just excluding so you get a different graph every time, you can do that with the Where.
other than that, you shouldn't column scope col.
:col == {1} // won't work
col == 1 // will work
ajgarnello
Vince,
Thank you for this information, I understand that my current method likely isn't the most efficient. If the Where segment of your suggested code will indeed exclude rows with cell-values of 1 for the respected Rand column, what is the syntax? This will solve my problem!
ms
Super User ms
Not sure what you aim at in the end, but this is one way to iteratively update the data filter:
dt = Open("$SAMPLE_DATA\big class.jmp");
dt << New Column("Rand001", Formula(Random Uniform(0, 1)));
dt << New Column("Rand002", Formula(Random Uniform(0, 1)));
dt << New Column("Rand003", Formula(Random Uniform(0, 1)));
// "Blank" data filter object
df = dt << Data Filter(Mode(Include(1)), Inverse);
For(i = 1, i <= 3, i++,
    col = Column("Rand00" || Char(i)); // Dynamic col variable
    df << delete all; //Remove old columns from df
    df << add filter(Columns(col), Where(col > 0.875));// Add current column
    Wait(2); //Delay just for demo purposes
But the approach of Vince above, to include a where clause in the analysis platform instead of using a data filter may make more sense here.
