DNAFoundry
Iterate through columns and model each
I have 3000 response variables and i would like to iterate though them and run a fit model on each. What I would like to do is record somewhere which columns have certain main effects as significant for further analysis. I think the sensitivity of my instrument (mas spectrometry) makes this a valid approach. Any help appreciated!
Dave
Re: Iterate through columns and model each
I believe that what you can do, is to run Fit Model, and place all 3000 columns into the response area, then build the model and run it.  Once it is completed, just right mouse click on one of the "Effect Tests" tables and select "Make Combined Data Table"
It will give you a data table with all of the results, whcih you can then determine which response variables had which significant effects, etc.
DNAFoundry
Great stuff yes, it works!
