landra_c
It's time to get JMP 15
The latest versions of JMP statistical discovery software, JMP 15 and JMP Pro 15, are now available.
JMP 15 brings a variety of new graphical enhancements, from header graphs in the data table to graphlets to bar charts and histograms in the local data filter.
The latest version of JMP also includes:
  • A new PDF import wizard.
  • Group Orthogonal Supersaturated Designs (GO SSD).
  • An enhanced Functional Data Explorer.
  • Support Vector Machines (SVM) and Structural Equations Modeling (SEM) platforms.
  • An Explore Patterns tool.
For more details on these and other new features, visit New in JMP 15 and JMP Pro 15.
If you don’t have the latest version of JMP yet, see how to get JMP 15 here.
albest3
Community Trekker
Re: It's time to get JMP 15
Maybe not:
There seems to be to be backward incompatibility problem. In all previous versions of JMP (and my history goes back to alphaV1), once you saved a bunch of results into the Journal you could SAVE AS: MsWord.doc.
I'm looking at my my Save As dialog right now and dont see a .doc option. I'm supposing I can make do with the .rtf and/or .html option, but this does not make me happy.
Al
Ryan_Gilmore
On Windows, you can use File > Export to save a journal as a Microsoft Word document
albest3
Community Trekker
An excellent work around. Given that, for a Journal, there is no difference between Save As and Export, I wonder why it disappeared from Save As?
albest3
Community Trekker
I take it back. This is an almost worthless work around.
Using File>Export from a Journal to a MSWord.doc produces one huge graphic!
Prior to JMP15, you could Save As a Journal to a .doc and the tables would be (text) tables and the graphics would be wonderful full resolution graphics-metafiles. Working with these Journal.doc files was a joy.
... I guess I'll have to go back to .RTF for a workable solution.
DaveB
The "Save MSWord" command should still work so you should be able to do something like this
initName = (Current Journal() << get window title) || ".doc";
file = Pick File( "Save as MS Word", "", {"Microsoft Word 2000+ (*.doc)|doc"}, 1, 1, initName, 0 );
If( Length( file ) > 0,
	Current Journal() << save msword( file );
	Open( file );
I put that in the attached addin (using current window() instead of current journal()) and assigned it <ctrl-alt-w>.
