BookmarkSubscribeRSS Feed
josealvarez2685
Mar 6, 2015
It is possible, save a file JMP as .ascii???
6 REPLIES 6
Craige_Hales
Mar 21, 2013
Re: It is possible, save a file JMP as .ascii???
JMP data tables can be exported as CSV for use with other programs.  Meta data, like column formats and table scripts, is not preserved.
JMP data tables can also create a script (red triangle menu) that will recreate the table with the meta data.
Both of these are plain text formats.  If your table data has non-ASCII strings, the files will contain those strings.
Craige
pmroz
Jun 23, 2011
Not sure if this is what you're asking, but you can save a text string to an ascii file.  For example:
my_ascii_file = "c:\temp\test.ascii";
random_string =
"The quick red fox jumped over the brown log.
The quick red fox jumped over the brown log.";
save text file(my_ascii_file, random_string);
josealvarez2685
Mar 6, 2015
What I have is basically a table in JMP and I want to convert each column in a .ASCII file...???
pmroz
Jun 23, 2011
Try something like this:
dt = open("$sample_data\Big Class.jmp");
for (i = 1, i <= ncols(dt), i++,
    one_col  = column(dt, i);
    one_name = one_col << get name;
    one_type = one_col << get data type;
    col_list = as list(one_col << get values);
    if (one_type == "Numeric",
// For numeric columns convert number to character
        for (k = 1, k < nitems(col_list), k++,
            col_list[k] = char(col_list[k]);
// concatenate all column values together with a line feed between each one
    col_text = concat items(col_list, "
    one_file = "c:\temp\" || one_name || ".txt";
    save text file(one_file, col_text);
josealvarez2685
Mar 6, 2015
Thank you so much
thank you very much for the help
Now I have a folder with 500 files in txt format and want to import them JMP table, each txt file must correspond to a column in JMP. and each column must be added the name of the txt file.
appreciate your help
Craige_Hales
Mar 21, 2013
or if you want all the columns in one file, export to CSV via JSL like this (or use File->Save):
dt<<save("$temp/test3.csv");
loadtextfile("$temp/test3.csv");
"name,age,sex,height,weight
KATIE,12,F,59,95
LOUISE,12,F,61,123
JANE,12,F,55,74
JACLYN,12,F,66,145
LILLIE,12,F,52,64
Craige
