jacaalgo
Issues with opening specific worksheets from an excel file in JMP 11.2.0
I would like to report the following issues with JMP 11.2.0:
When I try to open excel files from a jmp script, the worksheet argumet to the Open message is not working. Even though I am specifying a single worksheet name, all worksheets are opened.
Also, when I select all non-wanted worksheets from the JMP home window and right click to indicate to close them without saving, the Save dialog window stills open. I have to close each data table one by one.
Has anyone else experienced something similar?
Article Labels
