samir
Issues to hide a text edit box in a radio box
I am trying to use a radio box that should hide/show a text edit box, but it does not work (see code attached).
Basically Choice 1 should show the text edit box, and Choice 2  should hide it.
I see at least 2 abnormal behavior:
1. if I clic several times on Choice 2, the text edit box is hiden, then shown, then hiden, then shown,... Although, it should stay hidden
2. Clicking on CHoice 1 does not always show the text edit box: it depends on the state of the text edit box before clicking...
I guess i am missing something fundamental
MyWindow = New Window( "Test...",
Panel Box( "Info",
		rb = Radio Box(
			{"Choice 1", "Choice 2"},
			<<Set Function(
				Function({self},
					match(self << Get Selected,
						"Choice 1", y << set text("Choice 1 is validated"); GB << show ();,
						"Choice 2", y << set text("Choice 2 is validated"); GB << hide (); //New Window( "HTRB Data Collection...",),
		y = text  box("If choice 2 , this box should be hidden !!!!"),
		GB = text edit box("if you clic twice on Choice 2, this is not hidden !!!!"),
		//GB << hide (),
pmroz
Re: Issues to hide a text edit box in a radio box
Not sure why your code wasn't working.  Maybe because you didn't supply an argument to hide?  In any event you can include the code inside MyWindow thusly:
NamesDefaultToHere(1);
MyWindow =
	Panel Box( "Info",
		rb = Radio Box({"Choice 1", "Choice 2"},
			choice = rb << getSelected;
			if (choice == "Choice 1", teb << hide(0),
				choice == "Choice 2", teb << hide(1)
		teb = text edit box("Some text to edit")
ian_jmp
Here's one way:
MyWindow =
	Panel Box( "Info",
		rb = Radio Box({"Choice 1", "Choice 2"}),
rb << setScript(
		if(
samir
Hi Jan,
Great it works !!!!
I m trying to understand...Is my code not working because I try to execute hide and show inside MyWindow ??
pmroz
MyWindow =
	Panel Box( "Info",
