DRemd
New Contributor
Issue with selecting individual window
So I'm trying to make a program that will open up some graphs in separate windows and have a save button that will  allow you to make changes to said graph and then save it. The saving functionality works except when you open a second window, clicking the button in the first window will save the graph in the second one. Is there a way to keep one button pointing to the window that it was created in?
Re: Issue with selecting individual window
I assume that you are getting your pointers to the different windows reset when you are openning a new window.  Here is a piece of code that illustrates one way of getting around that.  Check out the messages in the log when each of the "Push Me" buttons are clicked on
For( i = 1, i <= 2, i++,
	Eval(
		Substitute(
				Expr(
					__nw__ = New Window( "The Window " || Char( i ),
						__dis__ = Distribution( Continuous Distribution( Column( :height ) ) ),
						Button Box( "Push Me", Show( __i__ ) )
			Expr( __nw__ ), Parse( "nw" || Char( i ) ),
			Expr( __dis__ ), Parse( "dis" || Char( i ) ),
			Expr( __i__ ), "Button " || Char( i )
	Eval(
		Substitute(
				Expr(
