BookmarkSubscribeRSS Feed
Issue with Informat using JMP11
seb38360
May 15, 2017
I used jmp11 and I have issue when using the Informat function.
In column2, I used the following formula : Informat(:Datetime, "Mon/dd/yyyy h:m:s")
I have point instead of numeric result
Some colleagues using jmp12 doesn't have the same issue.
Do you know if it is a bug of jmp 11 or problem of configuration.
I try to check or not button in preferences indicating "Use JMP language rather than System locale settings ..." but it doesn't change something.
Regards
Sébastien
1 REPLY
Wendy_Murphrey
Jun 23, 2011
Try the following format/input format and formula.date.png
Wendy
