dijar
Is there any way to delete/remove select "Boundaries" from "Set Background Map" in Graph Builder?
JMP 12.0.1: I added some custom boundaries to JMP but now I would like to remove some from the "Set Background Map - Boundaries" options in Graph Builder. Is there any way to do this?
Thanks, Dijar
uday_guntupalli
Level VIII
Re: Is there any way to delete/remove select "Boundaries" from "Set Background Map" in Graph Builder?
@dijar : Try to right click on the background and go back to the same GUI where it let you add the background map - select "None" for background and that should remove the map.
Best
Uday
dijar
Thank you for the reply. I can do that but I would like to permanently remove this particular boundary from the "Boundaries" list not just remove the image from the graph.
dijar
