Is there an alternative to Shape function
uday_guntupalli
Sep 15, 2014
All,
    I would like to know if there is a good alternative to the "Shape" function (even UDF's - user defined functions  are welcome) .
// Generate Random Data
TestData = Random Shuffle(Random Index(10^4,10^3));
// Reshape the data using Shape function
TestData1 = Shape(TestData,10,N Rows(TestData)/10);
// Visualize data as data table
dt = As Table(TestData);
dt1 = As Table(TestData1);
   Visualize original raw random data - dt1
   Result of Shape function
 What I am hoping to achieve is convert the long format in dt1 or screenshot1 into wide format i.e.
Take "n" elements of Column1 and form a new column .
This is acheived using reshape function in most environments like Matlab and R . Wondering if there is a better way to do this with "Shape" or an alternative function .
Best
Uday
Best
Uday
Jun 22, 2012
Solution
You may get what you need from the pull down menus by using
     Tables==>Split
or
     Tables==>Transpose
markbailey
Jun 23, 2011
Solution
It isn't wrong to mix matrix and data table operations but it isn't necessary, either. Matrices offer many advantages over data tables in a case like this, though. These simple examples illustrate how you might form matrices with random elements of any shape:
Names Default to Here( 1 );
n = 10;	// rows
m = 10; // columns
// generate matrix in steps
x = J( n*m, 1, Random Integer( 1, 6 ) );	// column vector of six-sided die rolls
x = Shape( x, n, m );						// form into columns row-wise
y = Transpose( x );							// other way
Show( x, y );								// see what you got
// generate a pattern matrix in a single step
i = 1;
x = J( n, m, i++ );							// row-wise
// generate a n by m matrix of random elements in a single step
x = J( n, m, Random Integer( 1, 6 ) );		// row-wise
Jun 22, 2012
Solution
     Tables==>Split
or
     Tables==>Transpose
markbailey
Jun 23, 2011
In addition to Jim's answer, your script is really close. I would not expect JMP to work exactly the same as MATLAB or R, but it can accomplish the same results. The Shape() function in JMP works row-wise instead of column-wise as you expected. Simply apply the Transpose() function to the result returned by the Shape() function:
TestData1 = Transpose( Shape(TestData,10,N Rows(TestData)/10) );
uday_guntupalli
Sep 15, 2014
@markbailey :
         I have already tried that - however , the result looks like below - where I would have expected just 10 rows per column based on the function call .
@txnelson
         Can you provide an example of how to exactly call "Split" function to accomplish this as well .
Best
Uday
markbailey
Jun 23, 2011
Solution
n = 10;	// rows
m = 10; // columns
i = 1;
markbailey
Jun 23, 2011
When you become used to vectorized operations, you will think about the shape the whole way through, forwards and backwards. Applying only the Transpose() function won't give you what you want, of course. You have to change the Shape() function call in concert. In particular, you have to swap the number of rows and columns when you shape the original vector in anticipation of the transposition. Like this:
TestData = Random Index( 10^4, 10^3 );
TestData1 = Transpose( Shape( TestData, N Rows(TestData)/10, 10 ) );
dt = As Table( TestData );
dt1 = As Table( TestData1 );
Jun 22, 2012
Run the
     File==>Split
it will produce a new data table.  Go to the "Table Panel" at the upper left side of the new table.  There you will find an entry named "Source".  Right click on it and select "Edit".  It will show you the code it used to create the new data table.
