BookmarkSubscribeRSS Feed
charliem
Apr 4, 2014
Is there a way to enforce sequential execution of commands in a script?
If I run this command:
x = 1.5;
minimize( (t distribution(x, pooled_df[i])-0.95)^2, {x},<< Tolerance(0.0005) ) ;
print(x);
It bombs on the print command (or any other command that relies upon x).
Now, if I put a wait(5) in there it's OK.
But I would much prefer to jsut have the thing execute sequentially (in the sense that instruction n+1 doesn't begin until instruction n is done).
Is there a way to make JSL do this?
Thanks,
Charlie
pmroz
Jun 23, 2011
Re: Is there a way to enforce sequential execution of commands in a script?
Put wait(0) to "flush" JMP's queue.  I do this all the time to force sequential execution.
charliem
Apr 4, 2014
Do I put the wait(0) before or after the minimize( .... ) function? I couldn't find anything in the scripting guide about this... is it in some other documentation?
Thanks,
Charlie
pmroz
Jun 23, 2011
Put wait(0) after the minimize command.  I can't remember how I learned about this trick.  Folklore maybe?
Phil_Brown
Mar 20, 2012
It would be interesting to know if the following does what you want:
EvalList(
x = 1.5,
minimize( (t distribution(x, pooled_df[i])-0.95)^2, {x},<< Tolerance(0.0005) ),
print(x)
PDB
