andrew_grible
May 25, 2016
Is there a way to constrain actual forecasted output to non-negative results using ARIMA
Data-set does not have any negative values in it but when I create an ARIMA model and save the results -- at some low volume occurrences the platform will generate negative forecasts. Is there an option to "force" JMP to place a zero there instead of a the calculated negative value.
Thank you, Andy
jiancao
Jul 7, 2014
Re: Is there a way to constrain actual forecasted output to non-negative results using ARIMA
One popular approach is to use Log transformation on the response variable as a way of restraining the fitted values to be non-negative.
andrew_grible
May 25, 2016
Yes, thank you
