BookmarkSubscribe
andrew_grible
Community Trekker
Is there a way to automatically populate Input Variables for a Transfer Function forecast?
When you go to the Interactive Forecasting portion of the Transfer Function forecast output, JMP provides you a way to manually enter the upcoming Input Variables.
I want JMP to automatically pull those Input Values in and create the forecast.
Is there an option to flag or maybe code to add to a script to make this happen?
Thank you,
Andy
