lwx228
Is there a more efficient way to do this in JSL than in a loop?
After sorting jm by the age column, add a new column, find out the age of the adjacent rows up and down the age is not returned at the same time 1.I try to cycle and feel slow myself.Ask for better methods.Thank you very much!
New Column("new",Numeric,Continuous,Width(8));
dt[1,"age"]=1;
for(i=1,i<=Col Number(1),i++,
if(dt[i,"age"]==dt[i-1,"age"],dt[i,"new"]=0,dt[i,"new"]=1);
gzmorgan0
Re: Is there a more efficient way to do this in JSL than in a loop?
Note, the script you pasted does not match the script in the screen shot.
Names Default to Here(1);
dt << Sort( By( :age ), Order( Ascending ), Replace Table );
dt << New Column("new",Numeric,Continuous,Width(8));
t0 = hptime();
dt[1,"new"]=1;
for(i=2,i<=Col Number(1),i++,
t1 = hptime();
dt << New Column("new2",Numeric,Continuous,Width(8));
t2 = hptime();
column(dt, "new2") << set each value(
If(row() == 1,  1,
   :age == Lag(:age,1), 0,
   //else
	1)
t3 = hptime();
show(t3-t2, t1-t0);
//The results will be different each time, but the second method takes less than 50% of the time
//compared to the for loop.
//t3 - t2 = 257; t1 - t0 = 679;
lwx228
Thank you very much!I'm going to use the example comparison later.
