Is there a good example of a stability DoE?
I am running a stability study on a chemical compound made under different conditions.  Is there a good white paper or example on the setup and analysis of results?  The study involves both accelerated and long term environmental conditions under ICH Q1A(R2) guidelines.  I am running JMP 9.
Thank you,
Eric
