mattpace0
Community Trekker
Is the a method via vba automation to accomplish the same function as Drop Down Distributions > Stack?
From the Distributions drop down menu there is an item "Stack" which places the selected items in a horizontal layout, which is much more conducive for creating reports.
Is there a similar item available in vba automation please?
mattflynn
Community Trekker
Re: Is the a method via vba automation to accomplish the same function as Drop Down Distributions &g
// one easy option is to simple run a little JSL...
// Open sample data file - run distribution platform with "stack" option
Save Text File(
"C:\temp\DeleteMe.jsl",
Distribution(
Stack( 1 ),
Nominal Distribution(
Column( :age ),
Horizontal Layout( 1 ),
Vertical( 0 ),
Show Percents( 1 )
Continuous Distribution(
Column( :height ),
Vertical( 0 ),
Show Percents( 1 )
// modify to point whereever your JMP executible resides
rc = Run Program(
Executable( "C:\Program Files\SAS\JMP" ),
Options({ " C:\temp\DeleteMe.jsl"}),
show(rc);
Best regards,
-Matt
