BookmarkSubscribeRSS Feed
Is it possible to use for() loop inside a new window() call ?
tsl
Jun 23, 2011
I would like to write code like this :
myWin = New Window("window name",
  for(i=1, i<= NItems(myList), i++,
    outlinebox("New outline box for "||mylist,
      // add some content
I don't know beforehand how many items will be in the list ( it comes from a user entry dialog ).
A bunch of graphs get generated from a dataset based on the user's selections of parameters to chart.
I want to collate all the graphs together in a  custom fashion with a list of outlineboxes for each parameter in the list.
If I manually add a couple of them it is fine, even if using indexing subscripts to access the content I want which is referenced in a list, but when I wrap a for loop around the outlinebox() call I get an empty window.
Curious if anybody knows if it's possible to make this kind of an algorithm work. ( I'm using JMP 9.0.2 )
thanks
Thomas
David_Burnham
Jul 13, 2011
Solution
You can add content to a window by by sending the APPEND message to it:
nw = New Window( ... );
nw << Append( myContent );
where for your situation the myContent will the the outline boxes.  For multiple items you put the append message into the For loop.
Dave
-Dave
David_Burnham
Jul 13, 2011
Solution
Dave
-Dave
tsl
Jun 23, 2011
Thanks Dave, this works a charm ! I did not know about the Append message - that opens up a world of possibilities !
Thomas
