TheRealYeti
Is it possible to have interchangeable arguments in a function?
For example I have function like below:
my_function = Function(
        M_DATA      = Empty(),
        M_AGE        = Empty()
is there a way I can call the function like this
my_function( M_AGE = 12, M_DATA = "Useful info");
Age and Data were interchanged but function would capture it correctly?
Georg
Re: Is it possible to have interchangeable arguments in a function?
I don't think so, JMP captures the Arguments in the defined order.
If you would like to be Independent on the order, you could use a more complex data structure as Argument, like associative Array.
See example. BR
// function with single arguments
my_function = Function( {M_DATA = Empty(), M_AGE = Empty()},
	Show( M_DATA, M_AGE )
Print( "swapped arguments are ignored" );
my_function( M_AGE = 12, M_DATA = "Hello" );
// function with associative array AA
my_function_AA = Function( {Local_AA = Empty()},
	keys = Local_AA << get keys;
	For( i = 1, i <= N Items( keys ), i++,
		Show( keys[i], Local_AA[keys[i]] )
AA = Associative Array( {{"M_AGE", 12}, {"M_DATA", "Hello"}} );
my_function_AA( AA );
Georg
Georg
See example. BR
Georg
TheRealYeti
Thanks @Georg  for this work around! It is not very hard to implement.
Article Labels
