anders_bankefor
Is it possible to create classes in JMP Script?
Is it possible/where can I read about creating classes/DLL in JMP?
what I would like to achive within a script or several scripts:
Main script:
Creates graphics and calls for sub-classes/scripts
Sub scripts 1:
Imports and convertes raw data from excel
Sub script 2:
Make calculations
Sub script 3:
Make report
I need this division becouse sub script 1 and 2 has to be run several times.
Kind Regards
ian_jmp
Re: Is it possible to create classes in JMP Script?
Like most languages, JSL gives a lot of flexibility as to how to modularise your code to prevent it becoming verbose and to make it more maintainable. For example, you can 'include()' JSL from another file, define namespaces to prevent naming collisions, and define functions that take arguments or expressions that don't in order to repeat work. If you are unfamiliar with JSL and what it can offer, try 'Help > Books > Scripting Guide'. You mention DLLs, and JMP can call these if you need to: http://www.jmp.com/support/help/Dynamic_Link_Libraries.shtml
ian_jmp
Article Labels
