iliya
Is it possible automatically cast\convert .NET System.Data.DataTable to JMP.DataTable ?
Hello all
I am working with .NET framework need automatically use jmp application. Recently i met a problem, having data structure of the type System.Data.DataTable and need to convert it to the JMP.DataTable.
After some studying of JMP application interface i concluded that only way to do this is to walk in loop on each table entry in System.Data.DataTable and copy it to the corresponding
entry in JMP.DataTable .
1) My question is where simpler way to convert System.Data.DataTable to the JMP.DataTable ?
     Do you know any api that casts one type of table to another automatically ?
2) One more question is where some other .NET data structure(not System.Data.DataTable) that can hold table's data and can be cast automatically to the JMP.DataTable ?
Thanking you in advance
Iliya
