It’s World Statistics Day! To honor the theme of the day, the JMP User Community is having conversations about the importance of trust in statistics and data. And we want to hear from you! Tell us the steps you take to ensure that your data is trustworthy.
Invisible Tables
I've been doing some JSL programming recently which involves opening and closing a lot of data sets in rapid succession. Even if I minimize the windows or make them invisible as soon as I've opened them, I still get quite a bit of flashing on the screen which I want to eliminate. I'm currently doing quite a lot of this sort of thing:
mattf
Re: Invisible Tables
I don't know about making a data table visible, the the hint below a source of tons of great tips might help:
/* Jump into JMP(r) Scripting */
/* by Wendy Murphrey and Rosemary Lucas */
/* Copyright(c) 2009 by SAS Institute Inc., Cary, NC, USA */
/* SAS Publications order */
/* ISBN 978-1-59994-658-0 */
mpb
Super User mpb
Regarding opening an existing dataset invisibly, here's the response I got from SAS a while back:
"You cannot specify an invisible option when opening established data tables."
I requested that feature be added in a future release and you may want to do the same, adding to the vote count.
Michael
statganda
The show window command works for JMP 7 but not in JMP 8, why is it like that? Is there a different command for JMP8?
thanks
pmroz
I'm creating tabulations in a loop, converting them into a data table,
and then adding the results to a master results table.  I've
made the tabulation invisible, but the temporary data table does a lot
of flashing.  Any way to make the intermediate table invisible?
Here's some code from inside the loop:
style="font-size: 10pt; font-family: "Courier New"; color: black;">
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">current
data
table
style="font-size: 10pt; font-family: "Courier New"; color: black;">(
style="font-size: 10pt; font-family: "Courier New"; color: black;">surv_dataset)
style="font-size: 10pt; font-family: "Courier New"; color: navy;">;
style="">
surv_dme_tab
style="font-size: 10pt; font-family: "Courier New"; color: navy;">=
Tabulate(
style="">
Show
Control Panel(
style="font-size: 10pt; font-family: "Courier New"; color: teal;">0
style="font-size: 10pt; font-family: "Courier New"; color: navy;">,
style="">
Add
Table(
style="">
Column
Table(
Grouping Columns(
style="font-size: 10pt; font-family: "Courier New"; color: navy;">:
style="font-size: 10pt; font-family: "Courier New"; color: black;">Time
Period )
style="">
Column
Table(
Grouping Columns(
Period
style="font-size: 10pt; font-family: "Courier New"; color: black;">Serious
style="">
Column
Table(
Grouping Columns(
Period
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Labeled
style="">
Row
Table(
style="">
Grouping
Columns(
style="font-size: 10pt; font-family: "Courier New"; color: black;">MV
Name )
style="font-size: 10pt; font-family: "Courier New"; color: green;">
style="">
style="">
invisible
style="">
style="">
surv_onept_dt
surv_dme_tab
style="font-size: 10pt; font-family: "Courier New"; color: navy;"><<
make into data
table
style="">
surv_dme_tab
style="">
close window
style="font-size: 10pt; line-height: 115%; font-family: "Courier New"; color: black;">
style="">
surv_onept_dt
style="font-size: 10pt; line-height: 115%; font-family: "Courier New"; color: navy;"><<
minimize window(
style="font-size: 10pt; line-height: 115%; font-family: "Courier New"; color: teal;">1
style="font-size: 10pt; line-height: 115%; font-family: "Courier New"; color: black;">)
style="font-size: 10pt; line-height: 115%; font-family: "Courier New"; color: navy;">;
I've tried changing the creation line to this but it doesn't work:
style="">
surv_onept_dt
surv_dme_tab
make into data
table
invisible
style="">
Thanks in advance!
Peter
Article Labels
